davisenvy wrote:
SDcampowneroperator wrote:
Ask the camp about the water pressure at your site, or even better use a gauge like we do. Its a simple 0-100 # gauge adapted to hose thread. Might cost you 10 bucks to make one.
If the camp pressure is less than 60 psi, skip the regulator.
You see, the problem with most regulators is that they also restrict flow, so you get a weak shower if the pressure is within acceptable range, less than 60 psi.
You could spend the money for a Watts adjustable pressure full flow regulator, but why bother and spend the money when its so simple to just check it out beforehand?
We have seen parks with pressures from 25 psi (la state park) - 110 psi ( Tx pvt.) . Our State law requires a minimum of 25 psi with a flow of 2gpm.
This is exactly what I was wanting to know. I need to get a pressure gauge. I think some of the places I camp have low pressure and the regulator just makes it worse. Thanks for the replies.
"Our state law requires a minimum of 25 psi with a flow of 2gpm".
What about a
*MAXIMUM* pressure?.
Having worked with municipal water systems - the pressure can (and does) fluctuate - especially at night time when demand on the system is low. Usually it's no problem.
However........
Depending on location, the supplying system *may* be very high pressure, regulated to (usually) about 80psi.
*Anything* is subject to failure, "theirs" too!
That's why a sticks and bricks house on a *municipal* system (city, county, etc.) has an adjustable regulator at the entry point.
When connected to any system, a "quality" regulator is a good choice.
The $10 RV variety are simply "restrictors".
Better than nothing - but not by much.
"Ask the park"..:h.. - the park *may* know, and be correct - but their method of regulating may be faulty or fail.
"Check it with a gauge"..:@.. - the reading you get is only good when you take it. Do you check psi at 3 AM?
"Do without"..:R.. - kinda like electrical surge protection. The only time you *really* need it is when there is (or was) a problem...:S
Failures of either can sure cause a lot of grief and "down time"...:(
Bottom line - as others have indicated - either use your water tank, and fill as needed.......or spend the 60 bucks or so for a watts regulator (Home Depot, Lowe's, etc.).
Your dice to roll........;)
