bpounds's avatar
bpounds
Nomad
Apr 22, 2018
Do you check tire pressures every morning?
You might want to reconsider.
We're planning our first outing next weekend, so yesterday I spent all day prepping truck and trailer. Checked all tire pressures. The trailer was down a few pounds, it hasn't been used since last August, and that ain't bad for so long sitting. Ran them all up to 70psi where I like to run them.
This morning I go out and one is dead flat. I was pretty sure what happened, because I've seen it before, but before I jumped to that conclusion I did a full inspection of the tire. They are nearing 4 years old, and have metal threaded stems, which were new with the tires. Found nothing.
So, of course it is a stem that did not seat perfectly when I disturbed it with air flow yesterday. I put a few pounds in and checked it with some leak detector soap. Confirmed, it is blowing bubbles.
Moral of this story is, if I had done that the morning of travel, that tire would have been flat fast. Better to have checked the pressure the night before, and then just give them a kick before hitting the road.
Or a TPMS if that's your thing.
