- my996duc1ExplorerI like the shelves, looks good .... I might copy that idea.
Can you post up the details on the stain used ?
Been thinking about changing the wiring on the lights above the headboard. Right now one siwtch on the passenger side controls both lights. Would like to have them wired seperately with a switch on both sides.
_ - RacormanExplorerThe wife wanted some shelves next to the upstairs bed. I matched the stain fairly well and finished installing them this morning...
Moderators Edit: Adjusted photo width to 640 pixels per the forum guidelines. The Photo FAQ's has help & tips for posting photos. - StrutterExplorerMine was doing the same thing. I just loosened the four bolts up on the head and started working.
- Macs_DadExplorerWow this post got really long.
All fuel stations normally have issue's with the gears swelling and making the breakers pop after a while. U can either change out the gears or get a new pump all together. - my996duc1ExplorerAnyone else have issues with the fuse blowing on the fuel pumping station on this make/model ??
I posted up in a thread already talking about this on a 2008 Weekend Warrior, not sure if it is the same pump or not.
_ - my996duc1Explorer
tom cav wrote:
my996duc1 wrote:
i got a tire lift and spare from cris a while back ,just waiting to see if i am going to do a hitch in the rear,.i was going to move over existing tire and place #2 tire close to it
Anyone have a second spare tire mounted up ??
Anyone ever need or use two spare tires.
I scored an extra stock rim and it won't do me any good sitting in my garage at home. Thinking about trying to mount it somewhere to keep as a spare tire setup (second spare tire).
Thinking maybe move over the current spare and mount the other one next to it if there is enough room.
Any other ideas ??
_
Chris suggested the same thing and mentioned drilling the second hole in the bumper. I wonder if moving the stock one over would it require drilling a new hole in the bumper for it also, making three holes across there.
I am also interested in doing a rear hitch... so I gotta keep that in mind also.
I wonder if it would fit up between the gray and fresh water tanks underneath. A person would have to put something up in there to bolt too. It would not be as easy to get to as the one mounted at the rear. - TRIPLE8Explorer
my996duc1 wrote:
Although not mounted, I carry a second spare in the basement storage
Any other ideas ??
_ - tom_cavExplorer
Any other ideas ??
_ - my996duc1ExplorerAnyone have a second spare tire mounted up ??
Any other ideas ??
_ - my996duc1ExplorerSide metal skirting installed ... Just gotta trim out and then center and re-attach the fender flares and this project will be DONE.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
