- my996duc1Explorer
mapguy wrote:
Racorman wrote:
my996duc1 wrote:
Anyone know what max PSI our rims are rated at on these ??
The weight sticker shows the weight capacity with the tires at 65psi. Is that what our rims are rated at or would it be higher ??
_
Mine stock tires are E rated and 80 PSI
At one time HiSpec had a different specification PDF posted with some language concerning PSI and rated capacity. I tried accessing the older PDF via the Internet Archive website but no luck.
Can always contact them (HiSpec)
I will ask them... just curious.
I have seen people reference a max psi on a certain rims. I am guessing these do not have a low rating of less than 80psi (max on the tires) or it would state it somwhere.
Thank you for the link ! - my996duc1Explorer
_
Yeah, my stock tires are E rated for a max of 3525lbs at 80psi.
I was just wondering if the rims had a max psi rating.
Just curious about it.... - mapguyExplorer
_
Can always contact them (HiSpec) - RacormanExplorer
_
Mine stock tires are E rated and 80 PSI - my996duc1Explorer
Racorman wrote:
my996duc1 wrote:
How often would you suggest a person to rotate tires and in what pattern do you rotate them ??_
My recollection was that the rear tires got more wear due to scuffing caused when you make your turns. Try to make your turns as wide as possible and that will help some. When I could measure the difference in tire tread, I switched the worse worn tires to the location of the least worn tires.
Next time you make a sharp left hand turn, poke your head out the window and you'll see how much the tires have to flex which causes them to scuff. :E
Thank you for the info.
I will keep an eye on them.
Since the rears are new they will have some catching up to do.
_ - my996duc1Explorer
_
http://www.hispecwheel.com/files/Series078SpokePDF.pdf
Oops wrong link above.
Should be this one: 3200#
http://www.hispecwheel.com/products/774/6-Spoke
My wheel has all the info in the link cast into the back of it. Even has the "3200LBS".
What I am not seeing is the max psi rating.
I have seen other posts where people discuss the max psi ratings of rims.... any ideas if these do not have a psi rating ?
_ - RacormanExplorer
Next time you make a sharp left hand turn, poke your head out the window and you'll see how much the tires have to flex which causes them to scuff. :E - mapguyExplorer
_
http://www.hispecwheel.com/products/774/6-Spoke - my996duc1ExplorerAnyone know what max PSI our rims are rated at on these ??
Racorman wrote:
Really nice work..... Hate to think it's gonna get dirty at some time ;)
When I had my triple axle toyhauler, I found it best to rotate the tires more frequently. You'll probably notice the most wear on the rear axle tires.
Yeah, have it all cleaned up right now.
I try to have everything (vehicles/toyhauler/ect...) polished and cleaned up before it gets worked on.... I would like to think the place working on it will take better care of it if it is clean.
_
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
