- MemphisdougExplorer
fj12ryder wrote:
The legs I've seen use a screw system to raise and lower the legs. There's no way for this system to drop the trailer unless the gears on the leg broke loose from the leg, and on both sides. I'd be really curious to see how this could happen. If someone knows, could they post an explanation please.
On the ones I've seen the motor drives a shaft witch has bevel gears on it. The bevel gears turn a screw that does the actual raising/lowering of the legs. The screws certainly shouldn't turn without power due to the friction involved. This keeps the legs from moving even if the gears, or motor, or both, fail.
I thought the same thing and that was why I was confused on how this could possibly happen. This is especially true since the OP said they were able to secure the broken motor and crank the trailer back up manually. The catastrophic failure of the landing gear required to have the trailer drop would not allow it to be cranked back up without major repair. - fj12ryderExplorer IIIThe legs I've seen use a screw system to raise and lower the legs. There's no way for this system to drop the trailer unless the gears on the leg broke loose from the leg, and on both sides. I'd be really curious to see how this could happen. If someone knows, could they post an explanation please.
On the ones I've seen the motor drives a shaft which has bevel gears on it. The bevel gears turn a screw that does the actual raising/lowering of the legs. The screws certainly shouldn't turn without power due to the friction involved. This keeps the legs from moving even if the gears, or motor, or both, fail.
I had to change the spelling of "witch" to "which". Sorry. Lousy proofreader: me. - blue_trawlerExplorerI think they said it was a gear! Thinking the motor was working, making noise but nothing was moving? A bolt broke off and the motor was moving around! Guys at the Rv park put a band around it and a shim to hold it still and we finally got the hand crank to move the Rv up a little to get it on the truck!
Bruce - MemphisdougExplorerI'm trying to figure out what failed in your landing gear that let the trailer fall "all the way down" as you said. That is not a motor problem. It doesn't even seem possible to me for that to happen.
- blue_trawlerExplorerYea u can use the 40 amp or the 30 John did an amp draw test. Said 30 will just make it pop quicker your total draw was 35 amps at first then drops under 30
This is what one of the techs said. He called the guy who worked on it!
Bruce - blue_trawlerExplorerThe motor just quit working! Rv fell all the way down after I got it off of truck and moved truck. Started to level it and BAM all the way down.
I'm thinking they said the gears in this motor are different will allow for more weight! It's slow. I asked today and they said I could use a 30 amp fuse if I wanted too?
Bruce - tdsxt51Explorer
B.O. Plenty wrote:
Chances are it's the same motor. If they're the std electric front jacks i don't know of any different motors. 40 amp fuse won't blow as easily. I wouldn't worry about it.
B.O.
If they up-graded the motor and didn't up-grade the wire size, YOU BETTER WORRY ABOUT IT! Won't blow as easliy?!? Eegads! I don't think that's very good advice! - fj12ryderExplorer IIIWhy did they replace the motor? Did it quit or just get really slow?
- B_O__PlentyExplorer IIChances are it's the same motor. If they're the std electric front jacks i don't know of any different motors. 40 amp fuse won't blow as easily. I wouldn't worry about it.
B.O. - blue_trawlerExplorerThanks Txiceman, I will call and find out? I haven't a clue!
bruce
About Fifth Wheel Group
