Durb
Aug 31, 2017Explorer
As you extend the landing gear the pin box is rotating rearwards a little. This may be the hitch plate sliding on the pin box plate while under pressure. I would try a teflon lube plate and see if that helps.
Maybe try it again with the truck in neutral with the e brake off and see if the noise subsides.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
