machunt's avatar
machunt
dometic fridge
i have a 2010 keystone m fridege after pluged in for a week in outside temps of 50-60 deg temp 38-40 deg slider is at the top of fins. i cant imagine what will happen when the outside temp is 90 or better. please help
  • machunt wrote:
    thermister is on the first fin from the right as looking at it. when u sayy unplug u mean from the back of the fridge. outside
    YES.
  • thermister is on the first fin from the right as looking at it. when u sayy unplug u mean from the back of the fridge. outside
  • Also make sure the thermometer you are using is accurate. I once had what I thought was a good thermometer and it turned out to read 10 degrees higher than actual temp.
  • What "fin" is the Thermistor on as you're looking at the inside of the frig?
    AND
    Think North ... UP (colder) .... South ... Down (Warmer)
    To Test:
    Unplug the thermistor and let the fridge run essentially uncontrolled but check every few hours to avoid freezing, if it cools you have a faulty thermistor.
