Rism47
Apr 26, 2016Explorer
Dometic fridge
Hi all, I just bought a used tt trail-lite 8280. It has a Dometic rm2652 2 way fridge in it. When I tried to use it it had no power from the inside controls. After reading online I checked 120v at rear of fridge to control board and it was good. Checked 12v and it ended at the thermal fuse in the boiler covering. I presses the reset and the fridge kicked on. That fuse keeps tripping after only 2-5 minutes. Also there is a yellow haze on the boiler cover which if I'm correct may be the ammonia refrigerant. Any advise?
Thanks,
Dan
Thanks,
Dan
