bigdave720's avatar
bigdave720
Dometic RM2852 problem
My fridge is only running on lp right now. I had a mobile mechanic come out and his diagnosis was the lower control/circuit board. I decided I would change it myself since it looked pretty straight forward. Problem is I can't find the lower board anywhere. What am I missing here?
I paid him for doing a couple of other things I needed but looking back maybe I should have let him do it.
Anyway......
  • May I suggest you take a photo of the wire connections before you remove any wires. Makes it a lot easier putting then back in proper order. Live and learn.
  • The lower board is under a plastic cover with a red dot on it at the bottom of the back of the unit.
  • The service manual is here
    and the dinosaur board for the change is $100.
    board
    There is much to learn about trouble shooting it yourself just by looking for the board on google and following some of the links.
    links
    hope that helps
