elivi8 wrote:
Sometimes I wonder where you guys get your information. Costco has 115 Amp batteries for $90 each. This is the best deal by far and the way to go. 6 volts are nice but require lots of discharge cycles to actually maximize the usage. Typically this is 20-30 cycles which is way more that what most people use their RV, so now you are talking about multiple years unless you use a battery charger at home. Also, if you lose a 6 volt battery, you are done. You can't run anything.
What group? Most cant fit 27's or 31's.. I personally can only fit 2 24's or 2 6 volts.
And I believe per trojon site all deep cycle batterys, even 12 volt grp 24's need 20-30 discharge cycles to meet max performance..
