elivi8 wrote:
Sometimes I wonder where you guys get your information. Costco has 115 Amp batteries for $90 each. This is the best deal by far and the way to go. 6 volts are nice but require lots of discharge cycles to actually maximize the usage. Typically this is 20-30 cycles which is way more that what most people use their RV, so now you are talking about multiple years unless you use a battery charger at home. Also, if you lose a 6 volt battery, you are done. You can't run anything.
How so i would still have 3 batteries left put two of them in series and you have 12v. As for discharge cycles dry camping without a generator and inverter running tv 3-4 hrs a day should take care of that. I have solar panels to recharge batteries.
