sdetweil wrote:
NC Hauler wrote:
Question: Do you know if your 5er ALREADY has a "place" marked out to put a dryer vent in place? 5er in my sig, had a place in the area where I now house our washer/dryer Splendide combo already in place, all that had to be done was line that up with the cut through the gelcoat.....I had mine done at Camping World (free install), over a year and a 1/2 ago and it's worked perfectly...but again, when I removed a piece of paneling out of the way, I could see my washer/dryer hook ups, electrical and water, as well as drain and also was a place pre-cut through first layer and it was re-inforced to add vent and cover through wall and onto outside surface , But outside surface did have to be cut...
just wondering if you might have an area "designated" as I did, for vent to pass from unit to outside?
he didn't want to go thru the side wall for some reason. these units do not have a lot of spare wall/floor space to do odd things.
I saw that, was just asking if the OP had a "designated area" to put the vent through the side wall, if he doesn't, then my question is moot...but if he does, I would opt to go that route....
To the OP, the longer the vent pipe, the more you have a chance to clog it up with lent and possibly cause a fire...most dryer vent's in RV's aren't that long...
