M_R_E_
Jan 15, 2022Explorer
Dumb mistake
I filled up my 5 gal can with diesei in back of pickup when towing and forgot to put cap on and drove for 3 hours in light rain. Will some water damage the fuel ? Is there something I could add to the fuel ?
mhardin wrote:
I would never knowingly put contaminated fuel into a truck with a $10,000 engine. If water makes it to the injector pump and it eventually grenades you will be looking at a huge repair bill.
MFL wrote:Cummins12V98 wrote:
Water will settle to the bottom, it will roll around on the bottom looking like mercury. Slowly pour it into another container thru cheesecloth until the water is close to coming out. Now let the new container set for a day and then pour most of it into your truck.
Slosh around the containers and then pour out and let them set upside down to drain. Done!!!
I agree, water is heavier, and your description may be a doable solution, if there is no way to replace the fuel. I have to know, is this what you would do, fresh fuel readily available, or would you be more inclined to follow my advice, previously posted?
No reply needed...I already know. :C
Jerry
Cummins12V98 wrote:This is the best advice here. The water WILL settle to the bottom, so don't pour the entire container into the clean container. Just let the clean container sit to make sure you didn't pour too much fuel out. As someone else mentioned, use the bottom fuel to start a fire.
TXiceman wrote:
Water and diesel engines do not mix, except in the radiator. Just dump the fuel. But dumping will be an issue for the environment.
Ken
Trackrig wrote:
And I wouldn't worry about it. If you were driving, then the majority of the rain blew over the bed of the truck. The 10 drops that went in it will be caught by your water filter.
Bill
