mielock's avatar
mielock
Dump valve replacement gone bad
I was mostly concerned about how to get a new dump valve in place with seals intact between two immovable objects until I tried to remove the faulty one, which I did not succeed. After removing the 4 bolts, the valve will spin, but the amount of force I applied to unseat it with no outward movement made me stop and ask for help. I've watched YouTube videos that show one or both sides of the valve to have flexibility in the plumbing, but for me, absolutely zero flex. The plumbing on either side of the valve is not moving anywhere. Any suggestions how to remove the valve and get the new one installed without seal issues?
  • In this instance, Fernco fittings can be drastically shortened with no ill effects.
