One of my dump valves has started leaking, just a drip for now . I have never had one of these apart, do you just take the 4 bolts out and slide the valve out and I would guess put new gaskets in. Any...
Well the valve has been replaced and put some water in tank to make sure there is no leaks. Not much room between grey tank and black tank for separation to put valve in, used ratchet strap to open and hold gap till the valve was in. Thanks for all of the info fellows. Rich
