- Chris_BryantExplorer IIThat’s an old furnace, most likely needs cleaning. If it is sparking the sail and limit switches are good.
- StirCrazyModeratori had the same issue with my camperi just bought. a good air gun and 10 min of blowing out the combustion side, it now works perfectly.
Steve - Roger10378Explorer IIProbably a spider web in the burner tube. You wouldn't hear the gas valve if the sail switch was not working.
- laknoxNomad
thetundrawolf wrote:
Hi, I have an older trailer with a Duo Therm 65900-001 furnace, it's getting propane fine, and 120v, when I connect the thermostat wires the fan comes on, and it sparks, I hear the solenoids in the propane valve click on, and I see it sparking in the glass window, but it never ignites. Any ideas on why it's not igniting?
Might be a bad sail switch.
Lyle
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
