eightydo's avatar
eightydo
Dutchmen Voltage 3200 Light Panel
Light Panel Voltage 3200
I added some LEDs behind my Light control panel. I used White LEDs 3per inch with sticky tape on the back (Flexible LED Strips & LED Tubing | NTE-Electronic Components Supplier)
A small Micro switch. I got power from the cigarette power plug. also switched it with a rocker switch in a blank spot (slide #3) switches are in series.
You can find pic's @ pinterest
http://pinterest.com/pin/298645019011106006/
  • Yes the micro switch turns them on/off when door is open/closed.
  • Nice job. Is that a microswitch to turn on the lights when the door is open? We took our door off.
    It's nice to see that they have increased the font size on the switch labels - we need a flashlight and magnifying glass to read ours.
