way2rollTrailblazerOct 16, 2020Easy way to tell what outlets are on my inverter?Our FW has residential appliances. I know the Fridge is on the inverter but I am unsure what else is. Oddly enough - our stove, which is gas, is not. It requires shore power for the igniter which I th...Show More
time2rollNomadOct 16, 2020Most likely nothing except the fridge will be powered by the inverter installed to run the fridge.
Related ContentInverter Bad?Adding power outlets in slide with no wiringElectrical outlet issuesInverter installOutlet problem
