cpaulsen
Jun 30, 2014Explorer II
57 Panhead wrote:MitchF150 wrote:
Not to diminish your goal of finding your post and your goal to tie down your awning, but from my own experience, once the wind gets to the point that you have to tie down your awning, you should just roll the awning up anyway... ;)
I have a 12 year old manual awning that I can just extend and leave the arms attached to the RV or move them out like a "car port" setup..
Mitch
The problem Mitch, is that with the kind of electric awning we have it doesn't take much wind to start shaking it around. With a manual awning you can leave it out safely in winds that would have me bringing mine in. We don't get to use it much as I seem to be bringing it in to often. With the kind of setup I'm looking for I could sustain as much wind as a manual with the legs down. I love the idea of deploying the awning with the push of a button but given the choice to do it over again I'd opt for a manual awning.
Thanks
Steve
These are the same ones I made and use all the time. Mine is electric and once I tilt the awning I put these up. If it really windy....it takes only a few minutes to take down and roll uo and by that time....everybody with a manual awning are rolled up also. I use a ratchet strap over the awning tube attached to a screw in stake that people use for dogs. I also drilled a hole at an angle in the bottoms of the supports so I can use a tent stake if needed. They work great and easy to make and are light.I think I drilled about 20 holes in each support approx. 1 1/2 inches apart.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
