fitznj
Jul 01, 2015Explorer
Check voltage at the Truck socket first;
Check for humming at each brake with the controller on
Check the breakaway cable and make sure its engaged
Check for voltage at each wheel (if you can get to the connectors)
Finally - check for a GOOD ground at each wheel (this was my problem when
I had similar issues) All grounds were connected together and then grounded
to the chassis - the chassis connector was bad thus each brake was inoperative.
Gerry
Gerry
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
