rb71 wrote:
Thanks for all the replies.
A 1500w heater requires 13.63 amps to run so if the tv or anything else is on its over loaded.
I like the idea of the generator box. But, I was hoping there was something where theres a male plug on the outside and receptacle on the inside.
Thanks Everyone
You're way overthinking it. We run a 1500 oil filled heater off any outlet in our RV and never popped a breaker. Sure, plug a hair dryer into the same outlet and you'll have an issue but use common sense and you'll never have an issue. Every big draw item in the RV is already on it's own circuit so unless you do something really clueless, you'll never pop a breaker. 5 seconds of forethought and planning will save you a completely unnecessary project.
