Old-Biscuit
May 23, 2013Explorer III
Electric stabilizers are usually feed directly from battery.
Check for power wires that bypass the battery disconnect switch....(front landing gear, slides, jacks etc.)
These lines have their own in-line fuses or dc circuit breakers (small rectangle box with two studs/can be auto reset or manual reset---small button on side).
These fuses/cb's can be under a cover or just mounted on wall typically via front compartment area.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
