steverea's avatar
steverea
electrical, is 13.4 volts normal?
I recently had the motor in my furnace replaced by an extremely experienced RV appliance guy. When I put the furnace back in it never ran right. The fan sounded weak. But it was putting out heat so I let it go a little while. then it quit working all together. so I checked the wires to make sure I had it hooked up right and it ran for a while and then quit again. Finally,I took it back to the guy and he said the new motor is toast. the brushes are melted and he suspects an electrical problem in the coach. I know very little about the system but I hooked up a meter to the wires that supply the furnace and I get a reading that fluctuates between around 13.2 and 13.6 volts. Is this a normal reading or is it high? The batteries are about 2 years old. I have two 12 volt batteries in series. the rv is always plugged in. The water level in both batteries is, and has been, good. thanks
