Cavie,
Thank you for the quick response. I guess I should have been a little more specific in my original post. Apoligies.
My camper runs on a 50 amp system. It's a 37 foot Sandpiper. The voltage read 238 at the hook up and 237 across the two main circuit breakers. This is where I get lost. I'm not sure how to check output voltage... Voltage across the converter circuit breaker to ground read 118. There is no fuse labeled for converter or inverter. I may be doing something wrong or backwards, I am not electricity savvy.
I'm assuming that the fridge, microwave and TV are all connected through the 30 amp system as they are still operational.
