time2roll wrote:
List all the markings to give hints and eliminate possibilities.
30 amp or 50 amp?
Does the fridge have power with this breaker off? You can unplug the fridge in the exterior compartment and run it on propane.
110v lights are not that common... were these OEM?
They are:
Main 30 amp
A/C
Gfi
W/h
D/S and below that 12v
I just checked and the fridge does not have power but works ok on gas.
It seems strange that the Gfi does not trip it but non of the wall outlets work.
Also the 110v lights do not work. I do not know if they were added as I did not buy the unit new.However I do not think so as they are the light above the diner and couch, it would be pretty dark in those areas without them.
The mystery deepens.
