tinner12002
Dec 06, 2015Explorer
Old-Biscuit wrote:
Lost 2 tires on same axle.......at same time???
Rear suspension has been over extended due to carrying all the load
Will need to support axle, remove tire/wheel, remove leaf spring eye bolt at equa-flex, flip equa-flex back up into position and bolt up leak spring
Repeat for other side
You might be better off taking the front spring hanger bolt out instead of the equa-flex because the spring may be too close to the equa-flex and not let it pass by.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
