kaydeejay
May 26, 2013Explorer
LocoMike wrote:Slide-out circuits typically DO NOT pass thru the 12V fusebox, but have in line circuit breakers somewhere near the battery.
I have power to the fusebox... but nothing to the 3 slideouts
anyone know of a wiring diagram I could look at,..
The reason is they have a heavy current draw and the voltage drop thru the fusebox is too much.
Check the fat wires from your battery positive to see if there is a manually resettable circuit breaker there.
Otherwise you need to trace the wires back from your slide motor to see where they lead.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 09, 2026
