Swamp_Man
May 27, 2013Explorer
If you wiggle the wire and there was a slight reaction from the slide motors, and the battery connections are clean and tight, sounds like a break in the line in that area. I would get a piece of #10 wire, and working from the battery, I would route it to the first connection. Try and see if things work. If not, keep on going to the second connection. Don't leave any protection devices out (fuse, circuit breaker, auto circuit breaker)but install the wire at those devices. Should tell you right away if you have a short circuit.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 09, 2026
