MFL
Mar 29, 2019Nomad II
goducks10 wrote:
Thats normal for a non bonded wall. The only things holding the outer layer to the 5er are the window, perimeter trim and lights. Or whatever else penetrates the wall.
Yes, many FWs with bonded firm sidewalls, do not have the same across the back. You can press on the inside back wall, and likely feel more give, than at the sidewalls. If no sign of water intrusion around rear window, inside or out, the units mentioned should not be a problem.
Jerry
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
