jimmy16x's avatar
jimmy16x
Exterior rear wall feels spongy
I've been considering buying a five or six year old smaller fifth wheel and looked at two nice ones yesterday that had a spongy feel on the outside rear wall. One was a 2013 Wildcat and the other was a 2015 Cougar. Both were 30 footers with a large rear window and below the window the fiberglass exterior would flex in and out when I pushed on it. Both sides of the window and above it and the rest of the walls felt firm and looked good. They were at two different dealers and the salesman at both told me that was fairly common on these models with large rear windows. Anyone had any experience with this that can give me some advice? Thanks
  • Yes that's'delamination', so drop the price $6 to $10, because that is what a dealer would sock you on trade in!
  • goducks10 wrote:
    Thats normal for a non bonded wall. The only things holding the outer layer to the 5er are the window, perimeter trim and lights. Or whatever else penetrates the wall.
    Yes, many FWs with bonded firm sidewalls, do not have the same across the back. You can press on the inside back wall, and likely feel more give, than at the sidewalls. If no sign of water intrusion around rear window, inside or out, the units mentioned should not be a problem.
    Jerry
  • The window has probably leaked. Also check the roof especially around the corners and ladder area. Check under the slides for soft or crunchy areas when you push up. Very common at the ends. Sometimes they leak and dry out and leave raised/bumpy crunchy areas.
  • Thats normal for a non bonded wall. The only things holding the outer layer to the 5er are the window, perimeter trim and lights. Or whatever else penetrates the wall.
  • I know those walls are typically of a "hung" variety, but I don't think they should be any different firmness than the side walls! I may be wrong, but I would suspect a small amount of water intrusion from the window or roof has made it spongy. Other potential issue is the wall materials have delaminated due to glue/adhesive failure. Not sure I would proceed much further without an independant inspection. Buying an rv with a leak or delamination puts your investment in jeopardy.
