bad99ram's avatar
bad99ram
Extremely Close Call
The other night our neighbor and wife were watching TV with the electric fireplace on. All of a sudden flames shot out from behind the TV ( fireplace is below the TV). He ripped the TV off the wall and grabbed the fire extinguisher. It didn't work. He was able to put it out with water before it spread. While checking out the damage he found that it was the remote control unit for the fireplace that had caught on fire.
After telling our group of the problem at morning coffee one guy went back to check his remote control . He found that where the fireplace plugged into the remote control had melted the wires and fused the plug right to the box. He cut the plug off, replaced it and is still using the fireplace minus the remote.
If any of you folks have a remote control for your fireplace please check it.
  • BTPO1 wrote:
    From reading your post it sounds like this started as an electrical fire (Class C). It then went to a wood fire (Class A). Water is fine for the wood fire, but if there is still power to that receptacle and you throw regular water on it there is a chance of being shocked. Just something to think about. As said earlier regular maintenance on the extinguisher would of prevented the water being involved. I also am glad that everyone was OK. JMO
    Water is also not the proper choice for grease fires I believe; but its the first (and sometimes only) thing people turn to when faced with fire.
    I think I would use it if faced with a similar situation and no extinguisher. (I have 3 however so I think I could get one going if had time.)
  • Listen up folks...
    I bought a 2004 Cedar Creek used about two (2)years ago. The remote didn't work correctly. It did one and not the other seems that it'd turn on the fireplace but wouldn't turn it off. I had to manually turn it off. Anyway mine is below the TV and is made by Dimplex. I believe that's the correct spelling, I'm not close to the camper at this time. When I called the Dimplex folks they informed me that there was a recall on the remote and the part that plugged n the 110v outlet. They even asked if it looked like it had been hot. My didn't it was just one function of the remote but they sent me a new module to plug into the wall and a new remote and I didn't need to send the old stuff back just tossed it. And all was at no cost to me.
  • From reading your post it sounds like this started as an electrical fire (Class C). It then went to a wood fire (Class A). Water is fine for the wood fire, but if there is still power to that receptacle and you throw regular water on it there is a chance of being shocked. Just something to think about. As said earlier regular maintenance on the extinguisher would of prevented the water being involved. I also am glad that everyone was OK. JMO
  • Unfortunate situation, Happy that occupants are OK, Sorry for their experience.
    I hope that they will notify both the RV manufacturer and the fireplace manufacturer of the problem.
    Posting provides 2 warnings for ALL:
    1. Check your electric fireplace for same conditions.
    2. Check your extinguishers on a regular basis. Pressure is important, but if the powder has had a chance to compact it will not help you when you need it. Need to keep it Loose and powdery like your flour.
