TeryT
Apr 15, 2021Explorer
I've not towed a 5th wheel like Barney, so I can't speak to that, but I can't speak highly enough about the Hensley. The story of how we got it was we rented a trailer before buying and the rental place had a weight distributing hitch on it, but we experienced severe tail-wagging-the-dog. My DW said to do whatever it took to never have that again. I already knew about the Hensley from being on here and immediately began looking for one, in which I "lucked-out" and managed to buy mine used from someone locally for about half a new one (I'm actually the 3rd owner).
And the Hensley is low maintenance too. In 16 years I've popped the bearing caps off to inspect on three occasions. The initial time, the previous owner had left it sitting outside (on the ground?) and I found that some water had migrated in. I replaced the bearings and then inspected it a couple times since and change the grease, but everything looked good both times after the initial.
Oh, they also recommend shooting some grease into it every thousand miles, through the two zerks. Easy peasy!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
