figgins
Oct 14, 2017Explorer
fj12ryder wrote:
My thought would be if the dry weight is 9000 lbs., the loaded weight will be around 11,000 lbs. That would put the hitch weight at 2200 lbs., or more, figuring 20 percent hitch weight. If you're over with a hitch weight of 1800 lbs. you'll be over more with the trailer loaded to travel.
I figured same percentage as dry hitch weight, around 17%, and perhaps not loaded to the very limit. At GVWR that assumption would put me at 1900 lbs hitch weight - just over the limit, but without passengers and weight of the hitch itself.
About Fifth Wheel Group
