justafordguy
Oct 17, 2017Explorer
fj12ryder wrote:
"You will need to see what is required in your state for registration weight. Be sure to register your truck for the max GVW it will actually weigh."
Some states, Missouri for one, require you to be licensed for your GCVW, not GVW. I'm licensed for 23,000 lbs.
Yep, Different for every state. In Florida if the NET weight of the truck is less than 8000lbs then you register for the max Gross weight of the truck. If over 8000lbs NET then you register for the Gross truck weight + the Gross trailer weight (GCVW).
About Fifth Wheel Group
