TXiceman
Jul 20, 2021Explorer II
The issue with adding additional fuel is weight and the weight limits of the truck. A 3/4 ton truck has a limited load capacity and the added fuel. Diesel fuel weighs about 7.2 to 7.5 LB/Gal. 40 gallons of diesel will add 300# plus the weight of the tank to the truck and reduce the payload capacity by the same amount.
Most 3/4 ton trucks with 5th wheels are nearing their rated load capacities without added fuel. Make sure that you will still be within your trucks ratings with the added weight.
Adding a tank with added capacity will not effect turning at all if you get a tank that sets below the bed rails.
Ken
Ken
About Fifth Wheel Group
