jlud wrote:
Ok, so made a post that hit about 7 pages pretty quick on going between motorhome and 5th wheel. After much back and forth, more back and forth, we thought that the 5th wheel might be the way to go.
Now, I sold my F150 last year and have been driving a work beater as we are deciding how to proceed. So, I call down and get the sticker payload off an F250 Screw Diesel XLT...it is only 2166 pounds for combined weight of cargo and occupants with the 10,000 gross pack......that is crazy..rear axle is 6100 pounds though. My 13 Ford F150 Screw had 1900 pounds of payload with the max tow package......
Anyways, on to reality. Most 5th wheels for what we want weight at least 10k pounds empty, up to 12, but lets use 12k pounds as loaded weight. With 200 pounds total for hitch and support, that leaves me with 1966...subtract wife and 4 kids (they are small now) but lets say 400 pounds, takes me down to 1566. Pin weight roughly 20% of weight, and of that 12k pounds, believe that would be 2400 pounds....
So 1566-2400 pounds puts me at negative 834 pounds....that is a quite a ways over...but I see all kinds of people using 2500 series trucks with these units.....
So am I supposed to buy an F350 to pull a 10k fiver? Or does everyone just run them overloaded on the gross but not on axle?
Thanks,
Herein lies your dilemma. Do you want to do it right, or just do it? You have very astutely described the #1 drawback and fallacy of the 3/4 ton diesel. IMO you will be better served doing it right and knowing for sure that you are within all the manufacturers ratings and by default you will be doing it safely, all other things being equal. Many will come here and say, it's only a couple of springs different, or it's just a sticker and means nothing, blah, blah, blah. It's your choice, and you know what the manufacturer has rated their equipment for. I say they have very good reasons for doing what they do. It's up to you.
