Gray Fox wrote:
I guess the battery tender is the way to go. We have 2 batters on the truck so would I need 2 tenders? Someone said to get the tender junior or should I get the tender senior?
Thanks for all the replies.
The batteries are hooked in sequence. All you need is one Battery Tender Junior. This one will never overcharge the batteries. Inside the package it should have a charger, cord and two separate style ends. One will be the clamps(I use this for the 4 wheeler) and the other is a split cord with 2 rings on it. Put the red + and the black - on your battery cable ends, route the rest of the connector through the grill and zip tie in place. Then you can leave it in place when all the time on the truck and just hook it up when wanted/needed. That's what I do.
