  • The R52 SEMA award winner is a special Commercial Tire.
    I used Commercial BF Goods and Mich - 200 each - they capture rocks and cut - esp in dually rear sidewall rock insertions.
    This SEMA award winner is all about an 80psi pothole survivor - sidewall breaches to date in off-roading 4x4 rocks and straight edge hits - zero.
    Contact Falken for correct construction info.
  • 3 ply Poly sidewall!!!! This is one heavy duty tire. The 235/85R16 weighs a pound more at 52 pounds. However, as Jimnlin states it is not in the same league as the steel carcass Rib or R250.
    I would put it in a true commercial grade poly carcass class with the Bridgestone Duravis R500 HD that I just installed on my TV and reviewed.
    With a 3 ply sidewall it might ride rougher than the steel ply sidewall tires, as I noted the two pile sidewall R500 rides a bit rough. Most poly carcass LT's are a single ply sidewall.
    Pricing:
    http://www.discountedwheelwarehouse.com/245_75_16_or_245_75R16_Discount_Tires.cfm?pn=FT-28697991&pID=60017
    Cheap! I would be interested to know how well they balance, keep us informed.
    Chris
  • A heavy fabric ply tire can't be said to be on par with a all steel ply carcass tire such as the R250 or Ribs.
    However the tread design looks like it would make a good tire for trailer service. And at 51 lbs is a plus and would be a excellent tire for heavy duty use on a trailer that spends its life on the road.
    I see Falken tires on trucks of all sizes but don't have any first hand experience with them.
    Have you priced them ???
  • I'm running Falken Rocky Mountain 18" load range E on my F150 and am quite pleased. They ride/handle good and carry the load well. JMHO
