Hap_Hazard's avatar
Hap_Hazard
Fiberglass siding question (updated 12-30-15)
Well once again I come to the experts for some insights and advise.
Before I start I want to say this question is for specific insights into the problem I'm having. I need specific suggestions for repairs.
I've been a member of this forum long enough to know how this question and comments can go sideways, so please help me by staying on topic. I really don't need opinions on my TH or a history of the companies management, or comments from the WW hater crowd.
I've owned this unit since it was new and have been more than happy with it. This will be my first repair outside of routine maintenance.
I have a serious problem that I need to know if I can repair this or will I need professional help.
Here's the problem:
Upon checking my unit I have found the curb side fiberglass siding at the right front corner of my 2005 WW FSC2800 has come out from under the trim molding. This unit has never been damaged and the roof seams have been maintained, see photo.
My questions are simple and straight forward:
1) How are the front and sidewall constructed and joined together?
2) Are they nailed, glued, stapled, or what?
3) Can the sidewall be pressed back into place and considered done or does the trim need to be removed and the edges brought back together and secured?
4) Because the sidewall appears to be bowed outward does the roof need to be raised to get the weight off the wall to get things back together?
I really appreciate any input as the closest repair shop is more than 300 miles away (each way).
Thanks in advance,
Hap
  • Y-Guy wrote:
    N-Trouble wrote:
    Before attempting to repair I would focus on what caused this to happen in the first place.
    Totally agree. Knowing why it happened it the key to a lasting repair. Panel shouldn't just pop out like that.
    Good advice, the proper way to handle.
  • Before attempting to repair I would focus on what caused this to happen in the first place. Having owned a 2004 WW Superlite and dealing with sagging outriggers which caused my curb side wall to drop 1-2" would be my first guess.
    There is a guy in southern California who goes by SoCal RV Doctor has a lot of experience in dealing with this issue on WW trailer
    http://socalrvdoctor.com/weekend-warrior/
  • that could be a pretty big job Hap. Like BB said pull the molding then at least you can see where it's come loose. The panels are attached to the framing under that molding, could be the staples have pulled out or rusted away.
  • I'd remove trim piece and seal/ glue it back together with 3m 5200. Park next to building or tree where you can use some 2x4's to press it back together while it dries then reinstall trim.
  • I would not get into that repair myself and I do most of my own stuff...even if you could get it back in, correcting why it came out in the first place is the larger issue IMO...
