Cummins12V98 wrote:
Inlaws RAM/CURT hitch in his LongHorn dually. He wishes he had the B&W but his came with the truck.
4 bolts of questionable grade holding the head to the base with the Curt and B&W has 8 grade 8. That right there is a HUGE difference.
Both hitches rated to 6,250# pin and 25K towing.
Not too hard to see what system is stronger.
Test? You mean like Andersen's "crush test video" ? That really proved a lot.....same hitch under hard braking alone caused the tubes to bend.
Also US Made VS China Made.
Why does he wish to have the B & W over the Curt?
You call those 4 bolts "questionable", so you don't know the grade, therefore how does that make a "HUGE" difference? Can't bolts be replaced fairly inexpensively?
How does one know that B & W didn't procure their bolts from the same factory in China that Curt did, just paid more for the head stamp?
I have a hard time seeing which one is stronger. They are both engineered the same, but someone is supposed to make the decision based upon visual appearance?
The crush test is valid. Anyone with an understanding of how physics are applied to such equipment with angular supports knows the legitimacy of such a test. In fact, the crush test exerts more pressure on the supports than any 5er on the market.
The entire internet world is aware of one Andersen UH hitch that failed with bent tubes. A more limited viewing audience (this forum) is now aware of one B & W Companion that failed. Score is tied. Move along.
US made vs. China made? Please clarify which is which. The Andersen is US Made.
