das's avatar
das
Fifth wheel hitch weight concerns
New to posting on the forum but have been reading for a couple of years and learning from other's experiences. We currently own a 7300 pound TT and are looking to upgrade to a fifth wheel. Looking at the Keystone 324FWBHS that is 10869 pounds and has a 2160 pound hitch weight. I have a 2015 Chevrolet 2500hd 6.0 that has a payload of 3152. Just looking for thoughts of the hitch weight concerns from other fifth wheel owners or am I just being parinoid? I know there is a big difference in the weight and payload but the 2160 weight is a huge difference from the 750 pound trailer tongue weight I am used to towing. Not totally stuck on the 324FWBHS model but do like the rear bunks and outdoor kitchen that come with it so I would also be up for ideas of something similar. Most of our towing will be less than 3 hours from home.
  • How come everybody says to add 200# for a hitch? I just looked up the shipping weight for a couple of large hitches, 18 and 20k, and they only weighed 143#. Maybe they are adding 60# of paint to cover the mounting bolts.
    Dave
  • As they've said a couple of hundred lbs for the hitch. Add in the DW, rugrats, fido and anything you want to stick in the bed around the 5er hitch.
    Looking at a 5th wheel you'll see most of the things your going to haul will be carried in front of the axles. With a lot of this going into the basement just behind the pin. This means that all of that stuff is going to add weight to your pin weight. Not a lb per lb addition but I use 80% as a conservative estimate, it's probably between 65-75%.
    If you only haul half of the trailers 3470 capacity you'll add about 1400 lbs of pin weight. Add that to your 2160 and your at 3560 on the pin. Don't even think about 2800 lbs if you max it out.
    My trailer has the same gross (13,500 lbs), I wouldn't trust single wheels on the TV for this kind of weight. My old truck had 19.5" tires and would easily carry the weight but the side walls were so stiff any rut would move you around. You'll need 4 tires on the rear axle of the TV for this kind of load. I see a lot of 3/4 tons pulling heavy 5ers but I don't travel close to them. They add helper springs or air bags but most of the time the rear tires are rated about 6200 lbs total.
  • .......and add a couple hundred pounds for the hitch.
  • That pin weight is probably based on dry weight not what it will actually weigh. You also have to add everything you are carrying in the truck: hitch, passengers, everything else. But you have a 1000# to work with.
