scottkeen's avatar
scottkeen
Fifth Wheel Towing Limit and Axle Ratio 3.73 vs 4.10
I'm in the market for a fifth wheel trailer and a truck. The 5er I want has a GVWR of about 14,300 lbs
One truck I'm looking at that fits my budget is a 2006 Ford F-350 DRW 4x4 6.0L diesel. It has an axle code of "37" which translates to "3.73 non-limited slip"
Is that bad?
Do I want a truck with limited slip or without?
I looked up on Ford's specs for the 2006 F-350 Super Duty DRW 4x4 and it says that both the 3.73 and the 4.10 axle gear ratio for that truck have the same GCWR of 23,500 lbs and 5er towing limit of 15,600 lbs
(see the screen capture)
So why get a 4.10 vs 3.73 when they both have the exact same limits? My only guess is that it's a tradeoff of higher speed fuel economy vs low speed torque.
