The advice on identifying the 5er of your dreams that will be matched with the truck of your needs. Again the best built, and higher quality units are Lifestyle Leisure formerly Carriage, Excel, Mobile Suites and then New Horizon. When you look at these units look at the frame construction. They all have very good frames. Look at the interior and the material used and the fit an finish. Yes they all retail for over 100,000 grand but they sell for about 30% or more less on the retail end. If you built one you can get what you want and with New Horizon you start with a blank slate. One of the most expensive and least functional options is the paint. If you can live with a white coach you can save 8-10 grand depending on the brand. If you can go to a major RV show, Hershey Penn. in Sep. and Tampa Fla. in Jan. which is nicer then Hershey you will be able to compare all of the brands side by side. Yes and go to the factories and see how they are built and the material used. Cedar Creek which is what I own and the Montanas, Heartlands and others are all good units. But you need to compare them to the others. Good luck.
