MFL
Mar 09, 2017Nomad II
I don't usually pay much attention to dry wts (8,160 lbs), but I think some are overlooking this entirely, and moving to worst case. With OPs 500 lb bike, he will still be under 9K. Now if you add another 2K+ of gear, normal stuff, it's still only 11K.
This TH has almost 5K CCC, that the OP states he won't be using. Even if he fills the 100 gal water, he'll still be on the short side of 12K.
IMO, this set up will work, probably some over truck GVWR, but under RAWR/tire max, GCWR. The scales will give final wts, but I expect a good towing experience.
Jerry
Jerry
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
