Lantley
Mar 09, 2017Nomad
MFL wrote:
I don't usually pay much attention to dry wts (8,160 lbs), but I think some are overlooking this entirely, and moving to worst case. With OPs 500 lb bike, he will still be under 9K. Now if you add another 2K+ of gear, normal stuff, it's still only 11K.
This TH has almost 5K CCC, that the OP states he won't be using. Even if he fills the 100 gal water, he'll still be on the short side of 12K.
IMO, this set up will work, probably some over truck GVWR, but under RAWR/tire max, GCWR. The scales will give final wts, but I expect a good towing experience.
Jerry
I agree to a point. THe first issue is you cannot trust the brochure dry weight number. What is the scaled dry weight? THe 2nd factor is the OP isn't even close on his ratings. What is his truck scaled ready to camp weight.
Based on what little factual data we actually have the 2500 3/4 ton truck is not rated for a 14K 5th wheel trailer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
