JIMNLIN
Mar 09, 2017Explorer III
We have a toy hauler forum....ask the mod to move you over there. I would bet someone over there has the same trailer/truck combo and has 1st hand experience how the combo works.
The trailer has a 13900 GVWR and a 4867 CCC = around 9000 lbs dry weight.
Dodge gives your truck a 6010 RAWR that will be carrying all the pin weight and other gear in the bed. Once you get the trucks actual scaled rear axle weights then you will know how much load in the bed it can carry. These trucks can have 3000-3400 lb rear axle payloads all depending on actual scaled rear axle weights.
The 2500 '08 Dodge/Cummins is the same truck as the 3500 SRW. Only difference is the SRW has a upper aux over load spring pack and higher rated tires and wheels. Many 2500 Dodge/Cummins packages come with the higher rated tires and wheel as my '03 has so all the truck needs is rear suspension help such as Supersprings/air bags/Kelderman System/etc.
I pull a 11200-11400 lb 5th wheel trailer with the same '03 3rd gen Dodge My trucks rear axle weights when hooked up run in the 5300-5400 lb range depending on how much "stuff" we load.
Check out the toy hauler forum.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
