Cummins12V98
Mar 09, 2017Explorer III
FilthyPlumber wrote:
Appreciate all the opinions and info. Checked my tires on my lunch and they are load range E 3195lbs.
Also, I plan on loading everything over the axels on the trailer. Not much if anything will be infront of the axles except what is needed to keep the pin from bouncing. Is this a good/bad idea?
MOST 5er's you will be adding weight on and mostly in front of axles. 20 percent pin is as light as most will be.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
