allen8106's avatar
allen8106
First Cat Scale Weigh In
2018 GMC 3500 DRW
9,375 - GAWR - Rear
5,600 - GAWR - Front
13,025 - GVWR
4,619 - Max Cargo
2010 Jayco 31.5 RLDS 5th Wheel
8,900 - Advertised dry weight
2,120 - Advertised dry pin weight
2,500 - Advertised cargo capacity
11,400 - Advertised GVWR
Loaded for road trip.
Truck and Camper
5,040 - Steer Axle
6,820 - Drive Axle
8,302 - Trailer Axles
20,180 - Gross Weight
Truck Alone
5,040 - Steer Axle
4,060 - Drive Axle
2,760 - Pin Weight
11,080 - Camper Weight
-I found it interesting that the steer axle weight was the same with or without the 5ver hooked on.
-320 lbs under 5ver cargo capacity.
-Truck weight includes, driver, dog, generator, 5ver power cable, blue boy tote, tackle box, fishing poles and cooler.
-2,555 lbs under drive axle weight rating
  • There you go 4619 for your max cargo capacity, sounds a little better.
