agesilaus
Oct 22, 2017Explorer III
midnightsadie wrote:
#1 stay calm ,cool and things are gonna happen, never get in a rush, thats when you,ll forget something, copy all the advice given and you,ll be just fine.
Double ditto on that. I've learned to take it slow, check and double check before any maneuvers. Be over cautious when you are starting out, going around corners in towns is a learning experience. You will come to appreciate the problems semi truck drivers have.
Oh yes gas stations, BEFORE you pull in take a careful look at how much room there is to get in and out. If it isn't easy in-and out, then stay out of that station. I only use the outside pumps, never the inside ones. I've seen folks get trapped in those inside pump islands. People will park in front or behind you and your rv, blocking you in. Also learn to be paranoid about any over any overhangs, tree limbs included. Forget about drive thrus in fast food joints, park in the back and walk in. I feel like Polonius, heh.
I also get the wife out to walk me into tight spaces like campground slots. Having someone watching the back of that mobile barn you are hauling around is priceless. Don't be concerned if you have to pull out and try again, much better that, than crushed sheet metal. Some get a pair of walkie talkies to reduce the shouting when doing this tho I guess modern smartphones can replace those.
If you seem to be having a problem helpers will congregate around you from neighboring sites. We are a helpful bunch.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
