one_strange_tex
Oct 24, 2017Explorer
agesilaus wrote:
Oh yes gas stations, BEFORE you pull in take a careful look at how much room there is to get in and out. If it isn't easy in-and out, then stay out of that station. I only use the outside pumps, never the inside ones. I've seen folks get trapped in those inside pump islands. People will park in front or behind you and your rv, blocking you in.
Good advice. I usually plan my fuel stops ahead of time. I often stick to truck stops since I have a diesel truck and you can usually be sure it will be easier getting in and out. Often I check out my stop on Google Maps' satellite pictures, including the ground level perspective, to verify my entrance and exit.
Walmarts are usually good for restroom, shopping or just leg-stretching breaks. The parking lots usually have room to place your trailer and generally move it around, but the same advice goes about scoping it out with Google Maps. Especially look for a stop light to help you pull out and get back on the road when you leave.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
